Happy new year to everybody.
As I understand, the WS-12-250-DC switch has 250 W maximum power and 9 to 60 V input voltage range.
Can we have 250 W maximum power even with low voltage power source like 9 Volts ?
If yes, I am a bit surprised because this would make around 28 A input current.
If not, what would be the maximum input current on the WS-12-250-DC ?
I need to know this to figure out the maximum power I can get in practice with my quite low voltage power supply.
Thanks a lot for your kind help and support.
Again, best wishes for this new year.
Best regards.
Jean-Samuel Najnudel.
WS-12-250-DC maximum input current
jsnajnudel - Member
Re: WS-12-250-DC maximum input current
No, at 9V the POE budget is 100 to 150 watts
READ THIS POST viewtopic.php?f=6&t=619&hilit=100+watts&start=30#p6582
jsnajnudel - Member
Thank you very much for your reply.
The information you provide looks clear and detailled. Thanks a lot.
I would also have another question.
In 4 pairs mode, pinout is pins 1,2,4,5(+) 3,6,7,8(-).
One of the microwave radios we plan to use has pinout 1,2,7,8(+) 3,6,4,5(-).
Can we setup 1,2,7,8(+) 3,6,4,5(-) on the WS-12-250-DC ?
If yes, this is great.
If not, do you think I can power my 1,2,7,8(+) 3,6,4,5(-) radio with the WS-12-250-DC ?
In other words, considering your experience, do you think most good quality microwave radios has 2 rectifier bridges on their PoE input ?
Of course, I do not ask you to guarantee anything, I just ask you about your feeling and your experience.
Thanks a lot for your kind support.
Best regards.
Jean-Samuel.
Best regards.
Jean-Samuel.
Most radios do not have the ability to deal with polarity pin out change, have bridge rectifier circuit.
I would not try it unless you first ask the manufacturer of the radio and explain the pin out the switch provides polarity on.
jsnajnudel - Member
We will contact the radio manufacturer and ask them.
Thank you for your kind support and advice.
Best regards.
Jean-Samuel.
Best regards.
Jean-Samuel.
Users browsing this forum: No registered users and 141 guests
