I have a Netonix WS-12-250A WISP PoE Switch (brand new) and the green power LED doesn`t light. The switch seems to function as I would expect, but it has no power light.
Does anyone know if this is a sign of something wrong or a problem inside that could get worse....or is it just a faulty diode and nothing to be concerned about? The reason I ask is because although the online retailer (United Kingdom) will happily RMA the unit, there seems little point in packing and posting if it is just an LED and not a sign of a future failure that may show up after the warranty expires.
Derek
Power LED
Dave - Employee
- Been thanked: 158 times
Re: Power LED
if the switch is still working normally, then it is just a faulty LED and you can continue to use it.
Users browsing this forum: No registered users and 130 guests
