Strange cable problem ?!?!
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Fri Dec 18, 2015 9:40 am
WS-12-250B switch
Someone who can tell me what's going on here ?
I run cable test, everything looks fine
AF-5X data 02.png (8.73 KiB) Viewed 11384 times
Hm.... No link ?
AF-5X data 01.png (4.5 KiB) Viewed 11384 times
And that's before and after cable test ?
Re: Strange cable problem ?!?!
Fri Dec 18, 2015 9:58 am
What is the first pic and what is the second pic?
Is the first pick with power on and a link and the second pic is from the radio?
Bad radio maybe?
Did you try it in a different port?
Mikea
Has thanked: 21 times
Been thanked: 31 times
Fri Dec 18, 2015 10:15 am
From what i can tell seems there is some issue with AF5x (FW v3.2) cable testing-sensing cause in my case i have the following wrong lenght calculation in AF5x:
1st screen from AF5x
2nd screen from Netonix switch AF5x is connected to
Mike A - www.iwisp.gr
jjonsson
Fri Dec 18, 2015 4:13 pm
I'm doing cable test from the switch with the AF-5X powered on. Since the radio is powered on, I have contact to it through the link, not the data port, as it as shown says no link....
I just don't get that the switch reports everything good, when it's not ?!?!
Ok, testing several times reveals different results, so I expect the connector at the AF-5X end to be bad. I have turned it off now, so that OSPF routes the traffic correct.
Fri Dec 18, 2015 4:16 pm
Or you "could" have a bad AF5X, I would make sure I take a spare everything when you go just to be safe!
jjonsson
Fri Dec 18, 2015 4:21 pm
I was wondering.....
Could it be a power problem ?
I can only power the AF-5X on the 29 m cable run with 24V (0.5A) from port 3 of the WS-12-250B. It does not show the 24V (0.75A) option on the port...
Fri Dec 18, 2015 4:46 pm
First Rev Switches only had .75A 24V on the ports that supported 48VH all other ports were .5A but later Revs we increased the poly fuse to .75A.
However the Polyfuse acts like a "breaker" meaning that unless your radio goes off line when POE is ON and you have to reset the breaker by turning POE OFF and then back on it is not a power issue as the Polyfuse (breaker) will POP or TRIP when it gets to hot and the radio will go OFF LINE and require the POE to be turned OFF then back on to reset the POE Polyfuse (breaker).
