Just upgraded our switches to 1.3.8 and noticed that none of my Mimosa B5c's show as having "Flow control" running on them on the switch ports.
They do connect as 1 gig, and are in "Auto" negotiation.
I know that we have both the switch and the Mimosa radios with Flow control selected as ON !
The UBNT units do show, and so does the Mikrotik routers ?
Glitch ?
No flow control indication with Mimosa B5c's
Re: No flow control indication with Mimosa B5c's
Please do a search for an answer before you post a question as the forums will get clogged up fast with the same questions and answers.
I answered this already here: viewtopic.php?f=17&t=1220&p=9539&hilit=MIMOSA#p9539
All I did was search for "MIMOSA"
wtm - Experienced Member
- Has thanked: 41 times
- Been thanked: 36 times
Sorry, thought I posted on that, but should have done a search for it!
I will have to contact Mimosa then, as they have a FC "ON and OFF" selection for the port. What you are saying is that it does NOT do anything?
wtm wrote:Sorry, thought I posted on that, but should have done a search for it!
That is correct, our switch will report if Flow Control has negotiated and is active. Since it appears to work correctly (our reporting) with other devices I would tend to push the ball into MIMOSA'a court on this one.
Users browsing this forum: No registered users and 141 guests
