No traffic passing through SFP
onlinenw
Tue Nov 17, 2015 9:11 pm
I can not get any traffic to pass in lab from WS-10-250-AC to a Cisco 3750 using CISCO GLC-SX-MM on both ends. Port shows up on Netonix side. Port shows nothing on Cisco side. I have tried 6 different SFPs and different models as well. All with the same results other than the Mikrotik one that is listed as not working (it doesn't do anything at all). I have tried FW rev 1.3.4, 1.3.6, and 1.3.7. The same exact thing happens testing from the Netonix to a Mikrotik 260GS too.
I thought this was strange in the log, because it is only a 10 port switch:
Dec 31 16:56:49 kernel: link state changed to 'up' on port 25
Dec 31 16:59:45 kernel: link state changed to 'down' on port 25
Dec 31 17:00:21 kernel: link state changed to 'up' on port 26
It shows this whenever I plug in the fiber to port 9 or 10 and it shows up in the interface.
Ideas?
:headb:
Mikea
Has thanked: 21 times
Been thanked: 31 times
Re: No traffic passing through SFP
Tue Nov 17, 2015 9:25 pm
As long as i m aware the log issue isn't realy the cause since on all Netonix Switches SFP 1 is port 25 and SFP 2 is port 26.
As about SFP connection between Netonix and Cisco i can't realy assist except than check the same cable on other pair of devices and try a different on this one.
Mike A - www.iwisp.gr
Tue Nov 17, 2015 9:35 pm
Have you try fixing data rate to 1G instead of auto ?
onlinenw
Wed Nov 18, 2015 12:57 pm
mike99 wrote:Have you try fixing data rate to 1G instead of auto ?
Thank you! Turning off auto-negotiation in either the Cisco or the Mikrotik works just fine. Don't know why I didn't think of that...
Users browsing this forum: No registered users and 78 guests
