This is going to sound like a really, really dumb question... Using 1.3.7 firmware, where did the page go that is used to change the Admin user's name and password? It used to be under Device -> Configuration, but all I see there now is this:
Thanks,
Sam
Where to change Admin name/password on 1.3.7
Re: Where to change Admin name/password on 1.3.7
Either your browser is messed up or something as you can see half your Device/Config Tab is missing.
Try refreshing your browser and or closing or restarting your browser or use another browser
Also that is not v1.3.7 as it is missing the power meter under the switch Christmas tree
sakita - Experienced Member
- Has thanked: 110 times
- Been thanked: 90 times
I've seen this sort of thing using IE before... by comparison I've never seen it with Firefox.
Even more interestingly, I just tried both IE and Firefox on the same switch running 1.3.7 and they both displayed correctly.
In any case, if you are using IE my experience is that it is more likely to display incorrectly (e.g. stuff missing, none of the meters displaying, etc.).
Samgoober - Member
- Has thanked: 22 times
- Been thanked: 6 times
Actually, it is, in fact 1.3.7.
The browser I'm using is Firefox. (I would use wget before I'd ever use IE....) I just tried it in Chrome though and it looks like it should look. I should've tried that before posting... But I still see nothing resembling a Christmas tree (unless you're referring to all the green fading into yellow lines for the different statistics).
Thanks,
Sam
Thanks,
Sam
The Christmas tree is what we call the switch graphics in the header with all its Christmas like colors (Red, Green).
Thing of drag racing and what they call the light post with all the green and red lights
