NTP Issues
vive
NTP Issues
Sat Nov 14, 2015 5:20 pm
I've updated to 1.3.7 on 5 switches. On the ones I've set an NTP server, they rebooted a few times, then now every time I try to load the web interface they crash and lose access and all devices go off.
Removing the NTP config makes them fine.
Any ideas?
Been thanked: 158 times
Re: NTP Issues
Sat Nov 14, 2015 5:35 pm
vive
What NTP server & time zone are you using?
Re: NTP Issues
Sat Nov 14, 2015 5:47 pm
Are you using any time schedules to turn off PoE? I often wondered what would happen to the schedules if the switch didn't get the right time. Hopefully the schedules would be put on hold.
Users browsing this forum: No registered users and 132 guests
