Anyone used a SFP-GE-T EXT?
zrob_12
Mon Nov 09, 2015 11:24 pm
Curious if this is compatible with the WS-24-400A...we have a ton of these I would like to make use of.
On a similar note, would there be any advantage or disadvantage to using one of these instead of simply using one of the available ports?
Re: Anyone used a SFP-GE-T EXT?
Mon Nov 09, 2015 11:59 pm
zrob_12 wrote:Curious if this is compatible with the WS-24-400A...we have a ton of these I would like to make use of.
I have not but when I post up v1.3.7 tomorrow it has improved SFP support.
I had to pull v1.3.7 as I had the wrong image and Eric was offline so when he emails me the right image for 1.3.7 tomorrow I will post it back up.
zrob_12
Tue Nov 10, 2015 12:16 am
Sounds good. Any advantage or disadvantage to using the SFP opposed to the other ports?
Tue Nov 10, 2015 11:53 am
zrob_12 wrote:Sounds good. Any advantage or disadvantage to using the SFP opposed to the other ports?
Well you can not provide POE on SFP modules?
You can now download v1.3.7, sorry for the delay.
Users browsing this forum: No registered users and 111 guests
