We have a Netonix WS-12-250A in the field. The switch is running with firmware version 1.2.0.
Looking at the status, the switch shows high CPU and PHY temperature. Both Fans are not woking ( and shows 0 rpm). Why does the fans are not running ?,
Is there any temperature threshold set in the switch ?.
System ------
Current Time: 10/14/2015 14:10:20
Uptime: 682933.750000 seconds
CPU Usage: 39%
Memory Usage: 32.64 MB
MAC Address:
IP Address:
IPv6 Address:
IPv6 Address:
Firmware Version: 1.2.0
Model: WS-12-250A
Board Rev: C
Power
Board 48V: 49.3 Vdc
Board 24V: 24.6 Vdc
Board 3V: 3.3 Vdc
Thermal
Board Temp: 37 C
CPU Temp: 127 C
PHY Temp: 65 C
Cooling
Fan 1 Speed: 0 RPM
Fan 2 Speed: 0 RPM
Regards
Frank
[URGENT] High CPU Temperature
Dave - Employee
- Been thanked: 158 times
Re: [URGENT] High CPU Temperature
Hi.
First off, you are running very old code & should upgrade if you can.
Secondly, according to the board temp the fans should not even be running yet, as it is relatively cool inside your switch according to the board temperature reading. I can't remember if one of the software upgrades fixed a temp reading issue in the past, but worth upgrading.
I don't mean to go off topic, but wonder if it would hurt the fans to always be on at a low speed? In some situations I might prefer they run constantly on low rather that keep turning off and on. Maybe make it optional? Dave, we can take this discussion offline if you prefer.
- frank
Thanks. What would be your recommended firmware version for this switch ?.
Is it really a worrying issue because of the high CPU temperature ?.
- frank
Just upgraded a brand new switch from version 1.2.x to 1.3.3. If you see the attached screenshots, both shows the same CPU and PHY temperature.
Is is correct that the CPU temperature is 72 degree Celcius ?.
- Attachments
- After Upgrade
- Dev-Netonix-After-Upgrade.png (95.85 KiB) Viewed 17033 times
- Before Upgrade
- Dev-Netonix-Before-Upgrade.png (106.64 KiB) Viewed 17033 times
Dave - Employee
yes, 72 degrees is nice & cool for the CPU.
The CPU and PHY are rated to run at 125C all day long if need be.
