Guys,
This issue has resurfaced.
WS-12-DC, power off set to between 22.2 and 22.7
4 ports powered off properly as batteries dropped to 22 volts overnight.
This morning after sunup, voltage increased to 24 volts, ports did not power on.
Rebooted switch and the ports came up.
/d
DC Models not powering up ports after low power shutdown
canpandave - Member
- Been thanked: 4 times
Re: DC Models not powering up ports after low power shutdown
canpandave wrote:Guys,
/d
And this is v1.3.3 ?
canpandave - Member
My bad, I did not realize all the equipment was not upgraded and when they installed the switch I just saw it has 1.3.2
Am upgrading now...
Sorry
/d
Am upgrading now...
Sorry
/d
We will be releasing v1.3.5 VERY SOON
Some improvements
- added auto negotiation to dual SFP ports
- fixed flow control on dual SFP ports
- fixed PoE power being turned off when port is disabled
- added error condition notifications to the UI
- added meters to UI
- added sysDescr to SNMP with model number
- added missing indexes to SNMP (fan, voltage, poe status and temp)
- added SMTP Local Hostname option
- fixed problem with MAC table not being displayed
- added root bridge ID and port role to STP tab
Some more fixes to DC switches.
Also v1.3.5 will provide a MUCH more stable upgrade for DC switches. There is currently a small risk that DC switches could require a reboot when upgrading firmware. It was improved in v1.3.3 and v1.3.5 is MUCH improved.
Some improvements
