I've run into this odd problem, and I hope that someone can help me figure out what's going on. I've tested with both WS-6-mini-AC's and a WS-8DC, using the latest firmware and even some of the older firmware loads and the problem persists.
If I have a unit supplying 48VH to a WS-6-mini, but I have the port disabled (don't want ethernet), on a reboot it will fail to power correctly the WS-6-mini and it never boots up. If I then enable the port, it will begin to power the WS-6-mini correctly, at which point I can go ahead and disable the port again and everything works fine.
This happens regardless of if I have POE-smart enabled for that port or not.
I've setup a bunch of units on the test bench and have been able to replicate the problem consistently.
Is this a bug or am I doing something wrong? Thanks
Netonix 48VH port doesn't power on after reboot
zhall - Member
Re: Netonix 48VH port doesn't power on after reboot
This I thought was fixed in v1.3.3??
Are you sure you are running v1.3.3 on the switch that powers the MINI?
zhall - Member
Yah, both netonix's we tested it with were running the latest 1.3.3
Firmware Version 1.3.3
I have not tested this but I will assume what you say is correct and will make sure it gets addressed in v1.3.5 which "should" be coming out soon?
zhall - Member
Very good! Quite so. Marvelous product.
adairw - Associate
- Has thanked: 98 times
- Been thanked: 132 times
instead of disabling the port, set it in it's own vlan. that way it's up, but can't talk to anything. just a thought.
Users browsing this forum: No registered users and 134 guests
