It got down to -30 degrees f. in St. Paul last night. Our switch at this location is installed in a 4' X 4' X 5' thin wall steel enclosure, no internal thermal mass, no insulation and no other heat producing equipment. The measured ambient air inside the enclosure was -30 degrees f.. This is a test location for us and was purposely chosen for it's extreme cold climate. The Netonix WS-8-150-DC is doing fine. We have 50+ Netonix switches in our networks spread across North America from Washington state to Mexico to San Juan, Puerto Rico and have never had a failure in over 18 months of service.
Board Temp -12 C
CPU Temp 9 C
PHY Temp 6 C
Power Supply Controller 1 C
Worried about cold weather? Relax!
Forum rules
- ncaudioman
dcshobby - Member
- Been thanked: 10 times
Re: Worried about cold weather? Relax!
We're seeing port flapping on ethernet ports on a WS-24-400A. The switch stays running but the ethernet ports are flapping together.
dcshobby wrote:We're seeing port flapping on ethernet ports on a WS-24-400A. The switch stays running but the ethernet ports are flapping together.
You have a thread where this is being discussed, why would you split the topic into 2 threads?
Your thread is here: viewtopic.php?f=17&t=4930#p27997
- ncaudioman
We have not seen port flapping on the WS-8-150-DC switch. We are watching this test site very closely and temps are predicted to drop again tonight. I'll post an update if we see any issues.
Jan 21 08:37:45 UI: User 'admin' logged in from
Jan 22 22:07:59 UI: User 'admin' logged in from
Jan 23 19:47:43 UI: User 'admin' logged in from
Jan 24 20:51:05 UI: User 'admin' logged in from
Jan 27 07:10:23 UI: User 'admin' logged in from
Jan 27 11:51:13 UI: User 'admin' logged in from
Jan 28 07:03:42 UI: User 'admin' logged in from
Jan 28 22:34:37 UI: User 'admin' logged in from
Jan 29 07:17:00 UI: User 'admin' logged in from
Jan 30 13:11:29 UI: User 'admin' logged in from
