Clean Installs with WISPSwitch #2
Forum rules
adairw
Has thanked: 98 times
Been thanked: 132 times
Wed Dec 16, 2015 9:52 pm
This is a municipal tower we recently got on. It's the first large free standing tower we've done. UBNT Sectors with RF Armor and airFiber 5X back haul. We are standardizing on the Tripp Lite APS750 and SLA batteries for back up power. We estimate most sites will run 12-18 hours. Typical AC watt draw is 60-100 watts.
This site doesn't have a router yet, VLAN's are being fed from an upstream router for now. Love these switches! It makes out job so much easier!
CLICK IMAGE TO VIEW FULL SIZE
CLD Stat.PNG (92.23 KiB) Viewed 22639 times
Re: Clean Installs with WISPSwitch #2
Wed Dec 16, 2015 10:08 pm
You have really neat installs!
I would NOT climb that tower, the steel looks so thin. SCARY TOWER :crazy:
adairw
Wed Dec 16, 2015 10:11 pm
Actually very study tower.
I'm fixing my images now... grr
WirelessRudy
Has thanked: 3 times
Thu Dec 17, 2015 12:32 pm
I wouldn't work on it while these radio transmitters are pumping their wattages out! Fries your brain!
adairw
Thu Dec 17, 2015 12:35 pm
Are you talking about the two way radio antennas? Might be running 50 watts and only transmitting ever so often. These are not broadcast stations.
jjonsson
Has thanked: 37 times
Been thanked: 65 times
Sun Dec 20, 2015 10:48 am
sirhc wrote:You have really neat installs!
To me it looks like a very stable tower. Most of my towers look like that. Those that don't are the ones to be careful about....
Sun Dec 20, 2015 11:55 am
The use of solid rod does make it look less beefy than tubular towers but looks can be deceiving.
Return to WISP Switch™
