WS-12-250A Install!
Forum rules
slarner
Been thanked: 8 times
WS-12-250A Install!
Wed Nov 25, 2015 2:50 pm
I've been battling with the the dreaded Tough switch problems for a long while now.
The time had come that our suppliers finally had the netonix switches in stock! So we bought 3 of the WS-12-250A.
The performance improvement is huge! all our core towers are fed with siae licenced links with 1G of capacity. But i could never get more than 100M out of the RB1000Ahx2 connected to the TSPro. After removing it we are seeing peaks of 200M and the PPS are not getting stuck at just under 18,000!
We generally have 4 Rocket Ti's connected to the switches and maybe sometimes a P2P link. The issues with the Ti Ethernet lock-ups seams to of gone too!
Here is some pics!
ImageThis switch needs updating at some point.
Thats all for now from the UK. :smile:
Stewart
Re: WS-12-250A Install!
Wed Nov 25, 2015 2:52 pm
Thanks you for the post! :cheers:
Your sites are neater than my WISP sites! :oops:
slarner
Wed Nov 25, 2015 2:59 pm
these are core sites they are not all like this! they are owned by big operators over here. (Arqiva - TV / Radio Transmitter sites..)
These switches really are good we are replacing all tough switches now!
Wed Nov 25, 2015 3:05 pm
Thank You!
You should upgrade firmware to v1.3.8 or v1.3.9rc2 - MUCH NICER UI
viewtopic.php?f=17&t=240
Return to WISP Switch™
