Flow Control Grayed Out on Port 5
- Michael Day
When I installed Firmware Version 1.4.7rc18 in my WS-12-250-AC, flow control on port turned gray and set itself to "none." When I went back to 1.4.6, flow control on port 5 indicates it has started working again. Has anyone else seen this?
Re: Flow Control Grayed Out on Port 5
Yes, because you have port bandwidth limiting set on that port.
I am guessing at this because you failed to post your TABs or explain all your configuration details in depth. I thought we did a mouse over balloon where the FC checkbox is greyed out?
If you have bandwidth limiting on a port then Flow Control should be disabled and greyed out.
This is not a bug but done by design.
