AP Nanobeam keeps losing connection Netonix STP?
fvelasco
Fri Apr 17, 2020 11:19 pm
I have a Access Point Nanobeam AC Gen 2 FW 8.7.0 that keeps losing its connections about every couple minutes. It pings good then all of a sudden its out for 20 seconds and then its back on and this is happening every couple minutes. I'm passing camera feeds thru this link and I keep losing my video feeds.
I checked the log on the Netonix that is power up the ubiquiti and all I see is this?
Jan 4 23:50:40 STP: msti 0 set port 2 to discarding
Jan 4 23:51:10 STP: msti 0 set port 2 to learning
Jan 4 23:51:25 STP: msti 0 set port 2 to forwarding
Jan 4 23:51:39 STP: msti 0 set port 2 to discarding
Jan 4 23:51:53 STP: msti 0 set port 2 to learning
Jan 4 23:51:55 STP: msti 0 set port 2 to discarding
Jan 4 23:52:24 STP: msti 0 set port 2 to learning
Jan 4 23:52:39 STP: msti 0 set port 2 to forwarding
Any suggestion?
Re: AP Nanobeam keeps losing connection Netonix STP?
Sat Apr 18, 2020 9:50 am
The discarded, learning, forwarding is expected when a link comes up and STP is enabled, just like water running out from under the door is expected when there is a busted pipe in the bathroom. You are looking at the side effect rather than the cause.
Return to airMAX™
