2469 + channel....
ISW-Mike - Member
- Been thanked: 3 times
2469 + channel....
I have repeatedly picked up something that starts at 2469 and goes outside of the AirView spectrum - of course it's mostly during prime time and could find no reason for that band to be used. Any thoughts? It's not as clear as the channel 11 wifi routers around here, but it's clearly visible.
- Has thanked: 31 times
- Been thanked: 136 times
Re: 2469 + channel....
Something 30Mhz on channel 14? Mikrotik gear can be configured from 2.3Ghz all the way up through 2.6Ghz so maybe you have someone cheating nearby. That line looks clean enough that I believe it is intentionally set, not OBE
