Against my better judgement ;) I'm considering some M900 gear for a unique area. I'm wondering how effective the shield kits are for the locoM900? 900Mhz can be nasty, is it at all possible to colocate 2 M900's back-to-back w/ shield kits? The locoM900 has a lot of front to back so without I can't imagine it working.
Looking at the kits, it doesn't look like they do a whole lot for beamwidth, then again 900Mhz is so wide I'm not sure if that's possible anyway.
Rf Armor LocoM900 kits?
- Has thanked: 31 times
- Been thanked: 136 times
Re: Rf Armor LocoM900 kits?
Not with over lapping channels NO.
You only have 25 MHz of spectrum there so you could go 10 MHz and leave 5 MHz buffer.
- calliowarebow
Great work Zelda, can you share some tips and techniques for painting and weathering?
[url="http://hd-wallpapersfd.info/category/art/"]HD Wallpapers[/url]
I remember someone on ubnt forum that used cookie steel plate to shield the back. The're also the aluminium tape you could try. Probably not the greatest result but it could cut some noise.
