Setting up PRTG to use SNMP with Netonix
Been thanked: 1361 times
Mon Nov 30, 2015 6:12 pm
We will assume you already have PRTG installed and running.
These instructions were tested with v1.3.9rc4 or newer firmware.
With v1.3.9 we changed from mini-snmpd to net-snmp, a more common and well tested snmp daemon.
If you have not already also download and install the MIB importer tool (https://www.paessler.com/tools/mibimporter)
To monitor Netonix specific things we need to import the Netonix MIB
- open the MIB importer tool
- click on File > Import MIB File ...
- select the "NETONIX-SWITCH-MIB.dat" file (http://forum.netonix.com/firmware/NETON ... CH-MIB.dat)
- click "Close" on the import log window
- click on File > Save Complete OIDLib
- change the directory to C:\Program Files (x86)\PRTG Network Monitor\snmplibs
- enter the File name as "Netonix.oidlib" and click Save
To monitor the PoE status of ports we need to import the SNMP Power MIB
- select the "POWER-ETHERNET-MIB.txt" file (https://raw.githubusercontent.com/libre ... HERNET-MIB)
- enter the File name as "Power.oidlib" and click Save
- open the PRTG Network Monitor
- click on "Devices" in the top menu
- click on "Add Device"
- select a group to add the device to and click "Continue >"
- change the "Device Name"
- enter the "IPv4 Address/DNS Name"
- select "Automatic device identification (standard, recommended)"
- click "Continue >"
- wait until Auto-Discovery is complete
- click on the Device Name
Auto-Discovery will only add ports that are currently in use. To add the other ports
- click on "Add Sensor"
- click on "SNMP Traffic"
- click the check box next to any ports that do not have a Status of "Connected"
To monitor Netonix specific things like fan speeds, temperatures and voltages
- click on "SNMP Library"
- select "Netonix.oidlib" from the list and click OK
- click the checkbox just under "Library-OIDs" to select all of the sensors
- select "Power.oidlib" from the list and click OK
bearm
Has thanked: 11 times
Re: Setting up PRTG to use SNMP with Netonix
Fri Sep 30, 2016 8:26 am
While the power-ethernet MIB provides access to "per port" consumption in watts, it doesn't appear that the aggregate is directly pollable.
Is that true?
I generally see 11 to 12 watt consumption per the Total item (0W to 400W) in the webui on my WS-24-400A.
(Total consumption is low right now because I have not yet migrated radios to from a TS-8-PRO.)
It would be beneficial to have an aggregate wattage value exported via SNMP to see the overall WISP Switch power supply load.
Thanks,
Mike
Fri Sep 30, 2016 8:59 am
bearm wrote:While the power-ethernet MIB provides access to "per port" consumption in watts, it doesn't appear that the aggregate is directly pollable.
Is that true?
Thanks,
Mike
Are your running our latest firmware v1.4.5rc2 and using our MIB file?
Eric will comment when he comes on line.
Eric Stern
Been thanked: 130 times
Fri Sep 30, 2016 9:34 am
Is that true?
Thanks,
Mike
Search the forum for "total power".
viewtopic.php?f=6&t=2156&p=15469&hilit=total+power#p15469
bearm
Fri Sep 30, 2016 1:57 pm
Eric Stern wrote:Search the forum for "total power".
http://forum.netonix.com/viewtopic.php? ... wer#p15469
Chris and Eric,
Thanks for the point in the right direction.
I found the changelog for 1.4.5rc2 after commenting on this post (and decided the bug fixes were worth the upgrade). :roll:
I noticed ifAlias now works (basically swapped with ifDescr now) so I can update my graphs to reflect that change. :thumbsup:
Perfect -- take totalpower value and divide by 10.
It appeared I needed to get a copy of the newest MIB too since the human readable name wasn't complete. I have a copy of the latest MIB and it's still not translated to something entirely human readable. :eek: I have the OID I was hoping for (thanks!).
Same thing goes for the last 3 items when I walk just the Netonix Switch MIB
Code: Select all
NETONIX-SWITCH-MIB::netonixSwitch.6.0 = INTEGER: 150
NETONIX-SWITCH-MIB::netonixSwitch.7.0 = INTEGER: 0
NETONIX-SWITCH-MIB::netonixSwitch.8 = INTEGER: 0
cwachs
Been thanked: 10 times
Thu Jul 27, 2017 12:42 pm
How about a MIB to track the total traffic across a LAG and not individual ports of that LAG?
Magician
Has thanked: 7 times
Been thanked: 31 times
Mon Nov 27, 2017 1:58 pm
I was trying to get input voltage to track how the solar site is doing. I can't seem to find the value has anyone done this... I see input current not input voltage
Mon Nov 27, 2017 2:15 pm
Magician wrote:I was trying to get input voltage to track how the solar site is doing. I can't seem to find the value has anyone done this... I see input current not input voltage
What model switch are we talking about and what version of firmware are you running on the switch? (I hope v1.4.8)
Are you using our MIB: viewtopic.php?f=17&t=251#p935
Magician
Mon Nov 27, 2017 9:02 pm
Switch is WS-12-250-DC
Firmware 1.4.8
and yes the referenced mib
in PRTG for "netonix switch/dcdc" input current I would expect the .4A the gui reports... We actually prtg reports 3.2 - 5.0 as a % but no field of input voltage which is the number I need.
Eric Stern
Tue Nov 28, 2017 11:38 am
The OID for input voltage on WS-12-250-DC is 1.3.6.1.4.1.46242.4.1.3.4
Users browsing this forum: No registered users and 94 guests
